webjwn Friend
webjwn
- March 2011
- 5 times in 2 posts
March 11, 2011 at 5:50 pm #161345Hello
I’ve just been migrating over to Joomla 1.6 with the Telavine IV template and need to make some adjustments to the widths of the Right-1 and Right-2 areas to accomodate my banner advertisement 3rd party system.
All my skyscraper banners are 160 x 600 and I think Right-2 has an inline width which I would like to change.
Where and how can I edit the widths of these blocks?
I have attached a screen show of what it currently is looking like with the banner in place.
aman204 Friendaman204
- January 2010
- 418 times in 356 posts
March 11, 2011 at 6:19 pm #380950You can go to template manager >> layouts tab
Edit the layout in use and change value here accordingly::
<blocks name=”middle” main-inner=”1″ colwidth=”17“>
khoand Friendkhoand
- February 2011
- 1166 times in 1060 posts
March 11, 2011 at 6:22 pm #380952Hi,
Choose Extensions–>Template manager–>JA_TELINE_IV – Default in backend. Choose LAYOUTS tab, edit default layout. Replace
<block name="right1">right1</block>
<block name="right2">right2</block>
to
<block name="right1" width="25">right1</block>
<block name="right2" width="25">right2</block>
Reference: http://wiki.joomlart.com/wiki/JA_T3_Framework_2/Guides#Custom_column_width1 user says Thank You to khoand for this useful post
webjwn Friendwebjwn
- March 2011
March 11, 2011 at 8:45 pm #380965Thank you both,
Both of your solutions worked!
Cheers
AuthorPostsViewing 4 posts - 1 through 4 (of 4 total)This topic contains 4 replies, has 3 voices, and was last updated by webjwn 13 years, 7 months ago.
Changing widths of Right-1 and Right-2
