callumgilhooly Friend
callumgilhooly
- June 2010
- 2 times in 1 posts
April 18, 2012 at 5:52 pm #176263Hi,
I’m using Orisite on Joomla 2.5.4 with Virtuemart 2.0.6.
For some reason, the checkout is showing errors related to prices (see attached screenshot). Now this was working a few days ago
The main errors are all variations of the following:
“NOTICE: UNDEFINED PROPERTY: VIRTUEMARTCART::$PRICES IN C:WAMPWWWDEVON4X4TEMPLATESJA_ORISITEHTMLCOM_VIRTUEMARTCARTDEFAULT_PRICELIST.PHP ON LINE 185”These also show errors on lines 186 + 322 / 323
I’ve checked these out and are all related to pricing. I have even tried turning prices off but it still shows the errors
The checkout works using other templates. It works with beez, JA_Ironis (but not ja_purity_ii or ja_tiris)
Any ideas?
I can’t give you access I’m afraid as it’s on a local wampserver.
- 2008 times in 1700 posts
April 19, 2012 at 2:31 am #449008Hi callumgilhooly,
This problem results from your undefined price value field. You have to go in virtuemart and define this value to get it work.
BR
1 user says Thank You to JA Developer for this useful post
callumgilhooly Friendcallumgilhooly
- June 2010
April 19, 2012 at 8:42 am #449082Hi BR,
Many thanks for your reply.
One question though. How do I define this value? I’ve looked all over config and shop and I can’t see anything. Is it a tickbox or a value?
Callumgilhooly
- June 2010
April 20, 2012 at 4:11 pm #449350Hi BR,
Can you explain what you mean by “Price Value Field”?
Is this an individual product price or a global setting that’s causing the problem?
If it’s a setting that’s wrong, why doesn’t the error show on all templates?
Callumgilhooly
chavan Friendchavan
- October 2014
- 1440 times in 1290 posts
April 21, 2012 at 4:18 am #449433Hi Callumgilhooly
JA Orisite was designed with VM 2.0.3, so you should remove or rename override folder templates/ja_orisite/html/com_virtuemart/cart
I hope it help!
Thanks,2 users say Thank You to chavan for this useful post
- June 2010
AuthorPostsViewing 6 posts - 1 through 6 (of 6 total)This topic contains 6 replies, has 3 voices, and was last updated by callumgilhooly 12 years, 4 months ago.
Checkout problem with Virtuemart
