  • Samer Semaan Friend
    #157293
    the slide show is displaying wrong on Chrome, i tested it on IE/Firefox,
    i attached a photo of the display on Chrome, the read more text is being displayed
    1. wrongdisplay
    Samer Semaan Friend
    #366700
    anyone is going to reply my question?
    Css Magician Friend
    #366707
    Dear icemaker,
    Please provide your live site to me, I will check and close your case.
    marryb Friend
    #377399
    I have the same problem with wrong slideshow displaying on Chrome. IE, Opera and Firefox is OK.
    Please … what was the solution of this problem?
    I am on Joomla 1.5.22 and JA Portfolio … running on my localhost.
    Thanks for your advice
    Martin
    Ninja Lead Moderator
    #377892
    We need to see your live sites to review this issue, please update in your tickets. In the meantime, you can try to disable the Read more button.
    marryb Friend
    #378948
    Please and how to I disable this Readmore button ? From module administration? There is only “Readmore text”.
    #378962
    <em>@marryb 224507 wrote:</em><blockquote>Please and how to I disable this Readmore button ? From module administration? There is only “Readmore text”.</blockquote>
    Dear marryb,
    Just select the field of Show Description to Description & Readmore then select Show Readmore Text to No .
    marryb Friend
    #379102
    thanks for your reply, but I have mod_slideshow2 (version 2.2.0-latest version) and in this module administration I donĀ“t have any of this options above … only this (see attached picture)
    1. settings_mod_slideshow2
    #379175
    Dear marryb
    It is strange that your moudule does not have those options,you can download then re-install the module or give me your FTP In the ticket RJI-642-70574 then I will have further checking on the issue for you.
    marryb Friend
    #379466
    thanks, I update this ticket now.
    #379564
    Dear marryb,
    I tried with the FTP Accout you gave in the ticket but could not connect,You can just try to use the ja extension manager component to upgarade the slideshow2 module to the latest version.
    I Hope you can do it yourself and it should help.
This topic contains 11 replies, has 5 voices, and was last updated by  Sherlock 13 years, 10 months ago.
