gaygiorgia Friend
gaygiorgia
- June 2008
- 15 times in 1 posts
June 30, 2008 at 6:44 pm #130326Hi, i’m experiencing some noising visualization problem with ja_news 1.3.1 module.
MY SITE OUTPUT PROBLEM:
———————————-> HOME PAGE DISPLAY #1
———————————-> ARTICLE DISPLAY #1
———————————-> HOME PAGE DISPLAY #2
———————————-> ARTICLE DISPLAY #2
NOTE:
the first article do not show text in homepage (see difference beetween 1) and 2) images).
the second articles (which has some </ br>) has visualization trouble… (see 3) image).What could be??
PROBLEMS EXPOSED ABOVE, ARE OF MY LOCALHOST. the real website online has different articles, but it has same problems.
I’ve temporally published my website. URL –> http://www.venetoinfo.it
gaygiorgia Friendgaygiorgia
- June 2008
July 1, 2008 at 9:29 am #257356i’ve done dozens of tries…
i can summarise all my tries in 3 types:1)installation A):
joomla 1.5.3 (ENG) + template teline2 v1.3 + setting everithing like USERGUIDE/QUICKSTART + CSS/JS MODIFICATION + THIRD PARTY ADD-ON (phoca gallery) + these modules:
– magazin menù
– main menù
– ja_news
– ja_news_fp
– latest news
– more popular
– 2/3 custom html (only text and links inside)
– syndacation module
– contacts module
– footer module
– search module
– phoca gallery2) Installation B)
joomla 1.5.3 (italian) + template teline2 v1.3 + setting everithing like USERGUIDE/QUICKSTART + NO CSS/JS MODIFICATION + NO THIRD PARTY ADD-ON+ these modules
– magazin menù
– main menù
– ja_news
– ja_news_fp
– latest news
– more popular
– contacts module
– footer module
– search module3) Installation C)
Quickstart Teline2 + SITE AND ADMINISTER SIDE ITALIAN JOOMLA TRANSLATIONS + CSS/JS MODIFICATION + THIRD PARTY ADD ON (phoca gallery) + CANCELLATION OF:
– ALL MODULES
– ALL ARTICLES
– ALL SECTIONS
– ALL CATEGORIES
– ALL MENU’S LINKS
+ CREATION OF:
– magazin menù
– main menù
– ja_news
– ja_news_fp
– latest news
– more popular
– contacts module
– footer module
– search module==============
OUTPUT RESULT:
Installations A) and B) have visualization problem showed at first post.
Installation C) (based on quickstart and totally cleaned of every content and module-menù) works good.PLEASE, since i’ve alredy 30 articles about in <a href="http://www.venetoinfo.it“>http://www.venetoinfo.it, (and it is an installation like B) type) please help me: find the problem!!!
:'( :'( :'(gaygiorgia Friendgaygiorgia
- June 2008
July 1, 2008 at 11:30 am #257381i’m re-installaing everything on the hoster.
new kind of installation: C) type. But PLEASE, find out the problem…questbg Friendquestbg
- May 2008
- 339 times in 197 posts
July 1, 2008 at 11:38 am #257383Hi gaygiorgia … let me know when your site is back so I can take a look …
currently, all I have is ” sito in costruzione … hosting su piattaforma”
- May 2008
July 1, 2008 at 11:40 am #257385Hi gaygiorgia … let me know when your site is back so I can take a look …
- June 2008
July 1, 2008 at 11:59 am #257391yes, thx. i’m now re-installing. wait 1,5 hours MAX about and u’ll be able to re-connect to online website. thx.
- May 2008
July 1, 2008 at 12:01 pm #257392<em>@gaygiorgia 63617 wrote:</em><blockquote>yes, thx. i’m now re-installing. wait 1,5 hours MAX about and u’ll be able to re-connect to online website. thx.</blockquote>
OK. Good Luck … shout me when site is back up and running! 🙂
- June 2008
July 1, 2008 at 3:37 pm #257428http://www.venetoinfo.it online pubblished again.
note:
this version is “quickstart” based, so it works.
to understand the BUG, please, use: joomla 1.5.3 eng, WITH NO DEMO DATA INSTALLED, then install teline2.gaygiorgia Friendgaygiorgia
- June 2008
July 2, 2008 at 2:10 pm #257615WHY, anyone among jart staff answer?
- May 2008
July 2, 2008 at 2:33 pm #257617<em>@gaygiorgia 63897 wrote:</em><blockquote>WHY, anyone among jart staff answer?</blockquote>
Hi GayGiorgia
I’m not JA staff, but I’ll reply, even if I can’t help … just because I’ve had a problem for five days now, so I’m frustrated too!
I had a look at your site, it seems to be working OK to me? I’m using Safari and everything seems to look quite good?
Apart from your ‘tabs’ … I think the names are too long in Italian so this causes following problem:
Let me know if I can help with anything else (although, I may not be able to as I’m quite new to all this stuff too!).
Is the problem that this is the ‘DEMO’ based pack? If so, that seems to be my problem earlier. I could modify existing sections/categories/menus, but as soon as I created ‘new’ and came away from Demo, everything went horribly wrong!!
Good Luck
Chrisgaygiorgia Friendgaygiorgia
- June 2008
July 2, 2008 at 5:15 pm #257641thx for your interest but u don’t understand:
1) now my site is working perfectly since i’ve reinstalled it with quickstart as i written here:
http://www.joomlart.com/forums/showpost.php?p=63607&postcount=3
2) problems still exist if i use a NOT QUICKSTART installation -.-”’ (please read first and second post of the thread…)
3) my tabs is ok. me and my friends see it without problems…– NOW –Since i PAYED, I PRETEND some1 joomlart answer to me. THX.
- June 2008
July 8, 2008 at 1:10 pm #258567this 3d needs an official solution: up.
Sherlock FriendSherlock
- 2478 times in 2162 posts
July 9, 2008 at 3:18 am #258688Hi gaygiorgia !
Sorry for delay ! i ‘m checking the problem . thanks for report !Sherlock FriendSherlock
July 9, 2008 at 4:23 am #258694Hi gaygiorgia !
About the Issue #2 : Image3 and image4 on your fisrt post
This is a error in trim html function of JA News module . You can fix it following some steps below :
1. Download attachment file and extract it.
2. Copy and overwrite to modulesmod_janews folder.Sherlock FriendSherlock
July 9, 2008 at 4:44 am #258697Hi gaygiorgia !
About Issue #1 : ( image1 and image2 ) don’t display text in front page.
This is error in max number character of JA News module , you can fix it following way below :
– Download blog_item.zip file and extract it.
– Copy and overwrite to modulesmod_janewstmpl folder. -
This topic contains 25 replies, has 4 voices, and was last updated by plinakos 16 years, 4 months ago.
