Viewing 10 posts - 16 through 25 (of 25 total)
  • Sherlock Friend
    #258698
    Hi gaygiorgia !
    You are super member ! thanks for all report ! JA will early update 2 error in new version for teline ii package ! (teline ii version 1.4 ) . 😉
    gaygiorgia Friend
    #258711
    tomorrow, after i’ll finish at 14:00 an exam at university, i’ll try and test your attachment modifications.
    Read my other two 3D about telin2’s bugs:
    1) mod_archive bug:
    http://www.joomlart.com/forums/topic/new-great-sux-bug-mod_archive-and-articles-with-images/
    2) <br /> bug in ja_news1.3.1 and ja_news_frontpage modules:
    http://www.joomlart.com/forums/topic/quickstart-installation-ja-news-1-3-1-shows-only-partial-text-or-nothing/
    #258714
    Hi all !
    Patch for fix JA News module :
    1 ) <br /> bug in ja_news1.3.1 and ja_news_frontpage modules
    2 ) error : max number character of JA News module
    Please download it and overwrite to modules folder.
    JA will early update it in new version of teline ii.
    questbg Friend
    #258722
    Hi Hainn84
    <em>@hainn84 65219 wrote:</em><blockquote>Please download it and overwrite to modules folder.
    JA will early update it in new version of teline ii.</blockquote>
    Am I correct in thinking I replace the helper.php file?
    Plus in the /tmpl folder I just replace blog_item.php as there was no blog.php in the download which is there currently.
    What I’m saying is … it’s just the helper.php file and then the blot_item.php file that need replacing with new version?
    gaygiorgia Friend
    #258729
    <em>@hainn84 65219 wrote:</em><blockquote>Hi all !
    yes it is a very good work. it fixes good ;).
    for everyone:
    wait 1.4 version of teline2, or download file attached by hainn84 and replace following files:
    – helper.php
    – tmpl/blog_item.php
    (inside it translate “MORE:” in what you prefer in your own language)
    – tmpl/index.html
    into folder:
    joomla installation root (http://www.yoursite.domain) /modules/mod_janews
    pls even here, change “answered” to “solved” 🙂
    questbg Friend
    #258735
    Does it fix the image wraparound problem (spacing) or am I hoping for too much? :p
    #258900
    Hi questbg !
    You can easy to solve the problem by way replace it by html code ( padding css ) to hspace. hspace is property don’t really popular .
    gaygiorgia Friend
    #259024
    <em>@hainn84 65462 wrote:</em><blockquote>Hi questbg !
    You can easy to solve the problem by way replace it by html code ( padding css ) to hspace. hspace is property don’t really popular .</blockquote>
    excuse me, i’ve not understand how to fix wraparound problem…
    coul u try to be explain better (even with an exemple thx 🙂 )
    questbg Friend
    #259027
    Agreed. If I edit the HTML, I imagine I have to change the “hspace=”18” bit of code? But, what to change this to?
    Seems there are other templates with this problem!
    plinakos Friend
    #262189
    Article Image is a blank black image in front page and news page as well! I have updated the ja_news module with the new fix but still the same.
    debug message:
    Warning: imagecreatefrompng() [function.imagecreatefrompng]: …thumbnails/thumb_gd_jan_2004.png’ is not a valid PNG file in …..modulesmod_janewshelper.php on line 112
    Warning: imagecopyresampled(): supplied argument is not a valid Image resource in …modulesmod_janewshelper.php on line 122
    ScreenShot:
    Also there are articles that are not correctly loading (maybe an image isssue) and I get this error, as a result jce lightbox does not work!:
    Thanks in advance for your help
    Petros
This topic contains 25 replies, has 4 voices, and was last updated by  plinakos 16 years, 4 months ago.
