February 3, 2011 at 9:12 pm #159720
I’m using joomla 1.6
I have 2 problems.
The biggest one is that when I click on “add comment”, it changes pages, but there’s nowhere to actually add or view the comments.
My second problem is that I have the settings to put the “add comment” form at the bottom, but it still has it at the top.
What am i doing wrong?!?!
nghiatd Friendnghiatd
- October 2009
- 39 times in 37 posts
February 8, 2011 at 9:32 am #375614Hello,
@but there’s nowhere to actually add or view the comments
You must enable jacomment component before using in that link
/administrator/index.php?option=com_installer&view=manage click on tab manage
then find component JA Comment and enable it.
@My second problem is that I have the settings to put the “add comment” form at the bottom, but it still has it at the top.
Please send me your admin and ftp account in this link:
http://support.joomlart.com/index.php?/Tickets/Ticket/View/63217/-1/-1/-1Best Regards.
February 8, 2011 at 11:27 pm #375704hello,
thankyou for your reply.
The comments work now!
but the “add comment” button is still at the top even though i have it set to the bottom.
i sent the admin and ftp info to the provided link.
- October 2009
February 9, 2011 at 3:09 am #375734Hello,
Please select position of comment button in plugin content jacomment follow my guide:
Login as admin click on menu
Extensions / Plug-in Manager then find plugin “Content – JA Comment”.
find the field “Position of add new button” then select position which you want to display.Best Regards.
July 20, 2011 at 6:13 pm #402146<em>@nghiatd 220215 wrote:</em><blockquote>Hello,
find the field “Position of add new button” then select position which you want to display.Best Regards.</blockquote>
It’s been a while. I thought i had abandoned this site, but now the people i was building it for want it again.
I’m still having the same problems. I am NOT using the artio joomsef plugin but I still get the “undefined” error. Also, “add comment” is at the top of the page even though I have it set to the bottom of the page in the options.
I opened a ticket here http://support.joomlart.com/index.php?/Default/Tickets/Ticket/View/63217/-1/-1/-1
please help!
thanks!
Stork11 FriendStork11
- March 2011
- 431 times in 393 posts
July 21, 2011 at 3:22 am #402190<em>@sloperawls 254468 wrote:</em><blockquote>Hi,
please help!
thanks!</blockquote>
Did you use the latest version of JA Comment? Please let me know if you already used the latest one but still got the problem. I will check it.
Please use this link to download the latest version: http://www.joomlart.com/forums/downloads.php?do=cat&id=20163
Best regards.
1 user says Thank You to Stork11 for this useful post
July 22, 2011 at 4:43 pm #402566<em>@nhatnx 254532 wrote:</em><blockquote>Hello,
Best regards.</blockquote>
I updated with the latest version and all my problems are solved.
Thanks!!!
This topic contains 7 replies, has 3 voices, and was last updated by sloperawls 13 years, 5 months ago.
