abdenour Friend
abdenour
- March 2009
- 2 times in 1 posts
January 3, 2012 at 3:24 pm #172389When I click on any item on the home page, I am not redirected to the article on which I clicked. I return automatically to the home page without displaying the full article.
Can you help me to solve this problem
pavit Moderatorpavit
January 3, 2012 at 3:52 pm #432299Hi
Could you post a link to your page ?
abdenour Friendabdenour
- March 2009
January 3, 2012 at 4:10 pm #432301Sorry, I can’t because it’s an Intranet website
January 3, 2012 at 4:57 pm #432310Please check in your template manager the profile tab if you have the Hide main content switched to Yes
- March 2009
January 4, 2012 at 9:55 am #432455The Hide main content is switched to “NO” on my template manager.
After installing the quickstart template, the links on the home page works well. Subsequently I did was change the names of classes of my articles and hidden some joomla modules. I have not touched the setup of the template. Out now all the links on the home page do not work and does not return to the article. As against the URL of the article in the browser address bar displays correctly after clicking on an item. All the mainmenu links work well on the homepage or on the others pages inside the website. My problem is only the articles who are on the homepage.
January 4, 2012 at 4:44 pm #432502Sorry but you have some problems on your site
1) Check your warnings extension manager warnings Tab you must set your tmp and logs dir as writable
2) there are some sql errors on category manager and article manager
I don’t know what happened before but i can suggest to reinstall again all using the quickstart package, the process can be done quickly if you make an export of your content table after done that you can make an import of your tables in the DB
January 4, 2012 at 5:05 pm #432516hi:
same problem!!!!
When I click on any item on the home page, I am not redirected to the article on which I clicked. I return automatically to the home page without displaying the full article.pavit Moderatorpavit
- March 2009
January 4, 2012 at 8:38 pm #432556I don’t understand. where i found the page assignements. On the mainmenu manager ?
If I remove the profil homepage this will it solve my problem ?January 5, 2012 at 3:10 am #432589problem solved:
solved the problem as follows:
add new category in main menu: eg: replace joomlart;
module manager: menu asigment Sl1-1 tick in new category created
featured articles: edit article: select category createdenjoy!
- March 2009
January 5, 2012 at 10:52 am #432634Hi 020166,
Can you explain exactly what you have do to resolve this problem. I haven’t undestand the 2 last lines of your thread.
featured articles: edit article: select category createdI understand I’ll go to tha mainmenu manager and after i create a new item on the main menu. after this i’ll go (on this new item mainmenu) on the tab “Module assignement for this menu item” and i click on the line sl1-1. after this, i select the box on the “menu assignement” the new item I have create before and save all.
Is it correct ? if yes, what will I do after.
- March 2009
January 6, 2012 at 7:37 pm #432828There is nobody on this forum to give me a response :((
- March 2009
January 6, 2012 at 7:57 pm #432832ok thank you. I look forward to your results
- March 2009
January 7, 2012 at 2:45 pm #432923Hi Pavit and 020166,
I have found the solution too after many hours to understand the functions.
1/ Create an article and assign it to a categorie like “Test”
2/ On the Ja News Pro module select the categorie “Test” and assign the module to the homepage for example
3/ Create a new item on the mainmenu manager with category blog and select on the right the category “Test”
4/ Now on the homepage when you clicked on the Janews pro module article test you are redirected to a new page (the new item you have created) -
This topic contains 15 replies, has 3 voices, and was last updated by abdenour 13 years ago.
