January 17, 2014 at 3:01 am #518784Please try to replace this file: templatesja_fixelhtmlcom_tagstagdefault_item_default.php with my attached file. Remember to backup your old files first.
fmfame Friendfmfame
- October 2013
- 25 times in 1 posts
January 17, 2014 at 10:05 am #518842now the image is gone, ok. But the styling of the article with “text” configuration is not the same like on “home” site. Its a complete other styling.
fmfame Friendfmfame
- October 2013
January 20, 2014 at 1:35 pm #519112there i only have a title but not in same styling like in “home” – site
Saguaros ModeratorSaguaros
January 20, 2014 at 2:54 pm #519118I’m still looking at this issue, give me more time, I will check and be back to you asap
January 21, 2014 at 10:30 am #519246Currently, in the tags page of your site, there is only article title. Please try going to backend > Tags Configuration Options and set Tag Description to Show.
Then the description will show, but you need to style for it a little bit as by default, there is no style for the tag page.
January 22, 2014 at 3:21 am #519326FYI: I’ve reported this to Dev team and they will provide style for this tags page, kindly wait for the update. You can check the status here: http://pm.joomlart.com/browse/JATCFIXEL-219
fmfame Friendfmfame
- October 2013
January 24, 2014 at 4:08 pm #519709I cant make updates because your templates has needed hundreds of customizations for a most “ISSUE FREE” version, also for compatibility for big components like jomsocial. So wallcrasher had made:
2 other js files, because your template/framework menu dont work with jomsocial menu, dont work good with easyblog or easysocial.Now i also couldnt make t-3 updates because t-3 is not capable of working with other components which have its own js files or have dropdown menus…
To using a template or a framework that has never been so complicated since i am working with joomla..So please help me on my page if dev team has a solution.
This topic contains 23 replies, has 2 voices, and was last updated by Saguaros 10 years, 11 months ago.
