swtinning Friend
swtinning
- July 2010
- 10 times in 1 posts
May 11, 2012 at 2:24 pm #176951Hi – I’m new to Joomla 2.5 and K2. Usually I fire-up Firebug and can figure out a solution.
However, I’m totally at a loss on how to locate and change the long black bar with the text ‘click to load awesomeness’ and to get it working like on the template.Spent 2 days so far on this minor issue and it’s driving me mad!!:((
Your help would be greatley appreciated. Am I being a dummy?
swissa Friendswissa
- November 2011
- 717 times in 572 posts
May 11, 2012 at 2:59 pm #452603<em>@swtinning 319135 wrote:</em><blockquote>Hi – I’m new to Joomla 2.5 and K2. Usually I fire-up Firebug and can figure out a solution.
Your help would be greatley appreciated. Am I being a dummy?</blockquote>
It’s a custom html module – so look in the module manager. Search for ‘click’ or look at modules in content-mass-bottom
Hope that helps!
EDIT: Ignore that, I’m being an arse. Give me a moment and I’ll try and find it – maybe someone jumps in in the meantime. :-[
swtinning Friendswtinning
- July 2010
May 11, 2012 at 4:09 pm #452614Thanks, but I’ve tried that. It’s a mystery because I’ve been using Joomla for 5 years and Joomlart templates for 2 years. Even the ‘smart search’ can’t find it?? Good luck…it’s a mind bender!!
swissa Friendswissa
- November 2011
- July 2010
May 11, 2012 at 4:45 pm #452630Hey dude…nice one! How did you work that out?? You’re a star!!
- July 2010
swissa Friendswissa
- November 2011
May 11, 2012 at 5:26 pm #452646Thank you for pointing that out. Team-work!! 😀
ron shafii Friendron shafii
- October 2013
- 7 times in 1 posts
May 11, 2012 at 9:16 pm #452673in the future if you can’t find where to comment out code you could also use PowerGrep. set it to search all folders and files in the template zip file and enter your search term. you don’t even have to uncompress the zip package.
This topic contains 9 replies, has 3 voices, and was last updated by swtinning 12 years, 4 months ago.
