  • marketeer Friend
    #959376
    Hi all!
    I need to enter code between the header tags and between the body tags of JA Argo template. An example of the code for the header section looks like this:
    if (typeof jQuery == ‘undefined’) {
    document.write(‘<script src=\"http://ajax.googleapis.com/ajax/libs/jquery/1.8.3/jquery.min.js\"></script>’);
    Which file or files do I access to enter the code?
    Best regards
    Try in this file /templates/ja_argo/tpls/blocks/head.php and add it at the end of file
This topic contains 1 reply, has 2 voices, and was last updated by  pavit 8 years, 4 months ago.
