April 18, 2016 at 8:50 pm #919463
Hi I use Uber template an I have the problem, that the collaps menu does not work in some screen width.. See picture menu-error0.jpg there is wide screen, no problem… Picture 2 smal screem no problem… Picture 1 there the collaps does not work..
Any Idea Thanks Theo
- Pankaj Sharma Moderator
April 19, 2016 at 2:55 am #919569Hi
The collapse navigation is working on your site the only issue is in that view of screenshot there is not enough space in the header to make all the items in single line .
If you want to collapse the navigation in the view go to /templates/uber/less/variable.less
Find this code// Point at which the navbar stops collapsing @grid-float-breakpoint: @screen-md-min;
Replace the @screen-md-min; value with th screen size like 1115px
// Point at which the navbar stops collapsing @grid-float-breakpoint: 1115px;
Save file and compile Less to css .
Kindly take full backup of site before applying changes ,, compile Less to Css will remove your custom style changes .
April 23, 2016 at 8:38 am #921789Hi
Sorry it does not work… I tried diffrent figures of page size, but no effect…
The menu collaps at the Size of the menu itself without calculating the size of the flags and the Offcanvas menusymbol…
Can you gif me a lift?
Regards TheoPankaj Sharma ModeratorPankaj Sharma
April 25, 2016 at 1:47 am #922280Hi
I am not able to access your site admin panel with submitted details . Kindly take a backup of site and correct the super user details , so i can apply my suggestion on your site .May 6, 2016 at 5:26 am #927441This reply has been marked as private.Pankaj Sharma ModeratorPankaj Sharma
May 6, 2016 at 9:17 am #927529This reply has been marked as private.May 8, 2016 at 7:21 am #928009Hi I do Backups regulary… so you can compile less to css. But I did it also.. no effect…
Did you change some thing?
May 9, 2016 at 1:04 pm #928434Hi
I replace the value with 1181px and compile the css . Please check your site now .May 10, 2016 at 12:45 pm #928937Hi Pankaj
Sorry it does not work… The problem is, that I get the two lines if the menu "mehr -" does not collaps and shows only the "-" Make your browser size smaler and larger…and see what happens
regards TheoPankaj Sharma ModeratorPankaj Sharma
May 10, 2016 at 4:13 pm #928997Hi
Please share the screenshot and screenshot where u getting this issue , Now the Menu is collapsed when screens size is below 1181px .May 16, 2016 at 11:10 am #931076This reply has been marked as private.Pankaj Sharma ModeratorPankaj Sharma
May 16, 2016 at 11:16 am #931077Hi
Please let me know in which device and screen size you are still getting the menu issue .
Becuase i applied the changes and its working on your site , i am not able to replicate it at my end ,
You may clean your browser cache and check , If still issue is there kindly provide me asked details .1 user says Thank You to Pankaj Sharma for this useful post
AuthorPostsViewing 12 posts - 1 through 12 (of 12 total)This topic contains 11 replies, has 2 voices, and was last updated by Pankaj Sharma 8 years, 8 months ago.
Colaps Menu does not work with mor menues…
