  • Pankaj Sharma Moderator
    #988384
    Hi Kindly apply my suggestion given Here for the same matter .
    If this does not help , kindly send me a temp super user detail and admin path of your site .
    I will check this issue directly on your site .
    Gruponea.com Friend
    #988555
    Gruponea.com
    #988558
    The sidebar was not enabled from template options > Navigation tab.
    I just enabled it and now its showing on site Homepage.
    Gruponea.com Friend
    #988568
    but i don’t want the off canvas sidebar, i want the "collapse navigation for small screen" bar. that is the one that it’s not showing off in the home page.
    Gruponea.com
    #988844
    Yu have custom work in the /local/tpls folder .
    I suggest you to remove the custom work , and replace the /local/feature-intro.php file with below file to use the same header
    Feature intro page has a special design that does not use Mega menu in it .
    1. features-intro.zip
    Gruponea.com Friend
    #988968
    Done it, now the menu it’s superposing with the logo. and the "collapse navigation for small screen" menu it’s not showing in small devices, just like before. Hope you can help.
    Gruponea.com
    Gruponea.com Friend
    #989107
    Hey Pankaj, i’ve managed to make the collapse navigation for small screen menu in all pages, the problem now it’s that the "regular" menu it’s superposing with the logo on the home page (featues intro). Is it possible to put the navigation menu first and the logo bar below?
    Gruponea.com
    #989177
    Hi If the menu used in the same header block it doesn’t show the collapse navigation . Feature intro page does not support mega menu due to its design concept . I spent a lot of time and did custom header file for you . You can see the my changes in new added file / local/tpls/blocks/header-new.php The only issue is the menu item in white color , that is due the the custom code from your custom.css file . Below i attached the file
    1. header-new.zip
    Gruponea.com Friend
    #989331
    Thank you very much for helping me pankaj, the problem now is that the "collapse navigation" menu it’s only showing on features-intro page (home) and not in the other sections.
    Gruponea.com
    #989342
    Please check it now , i just fixed it on your site.
    Gruponea.com Friend
    #989346
    Thanks Pankaj! everything it’s ok for now, i will let you know if I have any problems, Thank you so much!
    Gruponea.com
    #989352
    You are welcome ! I am closing thus thread as the issue is fixed . If you have any questions in future , do not hesitate to open a new thread.
This topic contains 12 replies, has 2 voices, and was last updated by  Pankaj Sharma 8 years ago.
The topic ‘collapse menu for small screens not showing on features intro page’ is closed to new replies.
