  • mbs13 Friend
    #992685
    I would to change this parameter ("Collapse navigation for small screens") from TRUE to FALSE. where can i change it?
    I am using the template ja_elicyon
    Thanks in advance,
    Rodrigo
    Pankaj Sharma Moderator
    #992753
    You can Turn off Collapse navigation from template options > Navigation Tab .
    Beside i suggest you to use your JATC account if you have to buy it to get support and updates for JATC templates .
    mbs13 Friend
    #992816
    I cant do it because it is hidden
    I am using the T3 framework version 2.6.2.
    Thanks,
    Rodrigo
    1. navigation
    #992933
    i checked the package and it has the option : http://prntscr.com/dgfm9o
    I suggest you to update the template and all JA extension to latest version if you have another JA Active account kindly use it or subscribe for template membership.
    Note : As per JA Support policy user should have an active membership account to get support and updates .
This topic contains 3 replies, has 2 voices, and was last updated by  Pankaj Sharma 7 years, 11 months ago.
