  • dohdaiga Friend
    #194659
    I really love your templates but there is always one thing that one has that the other doesn’t LOL. Anyway these two templates and i want to combine them… How do i go about this:
    I would like to create/add the same Collapsible top module and home-1 display from JA Fixel to JA MAGZ
    thnaks
    This is a complicated task due to different layout & style in different templates. If you also have JA Fixel installed, please check the header block: /templates/ja_fixel/tpls/blocks/header.php and you will see this code snippet:
    <?php if ($this->checkSpotlight('spotlight-1', 'position-1, position-2, position-3, position-4')) : ?>
    <a href="#fixel-top-panel" id="fixel-top-pannel-link" class="top-pannel-link t3-hide" aria-hidden="true">
    <i class="icon-chevron-down"></i>
    </a>
    <?php endif ?>
    Then you should use tool like Firebug and see how we style such in JA Fixel template, then apply into JA Magz template.
    dohdaiga Friend
    #522414
    I tried but, i am not an expert in PHP so i am not sure i am doing the right thing.
    If you can send the detailed instruction could you suggest an easy alternative?
    This requires knowledge about PHP and you must also style a lot because the style of these 2 templates is different. This custom work will take time so I’m afraid that I can’t help. I recommend you to hire a developer to get this done for you.
    Best
This topic contains 4 replies, has 2 voices, and was last updated by  Saguaros 10 years, 10 months ago.
