  • loci Friend
    #168420
    Hello to everybody i have a problem with the color layout.
    I don’t know what i have done but only on my machine when i will go to the site i look the blue template and not the default template.
    Anybody can tell me why?or how i can reset this problem on my machine??
    thanks a lot e regards.
    bye
    John Wesley Brett Moderator
    #412003
    Without a URL to view a little hard to diagnose.
    In the interim a few ideas,
    • Check EXTENTIONS > TEMPLATE MANAGER > your template > PROFILES > ADVANCED SETTINGS > THEME SETTINGS – see if the style you are wanting is selected
    • If you still have the CPANEL in the upper left…try changing to the version you want to see.
    • clear you cache and cookies both site and browser
    Have fun
    John.
    loci Friend
    #412006
    U have your reason….
    http://www.casasassolo1713.com
    i have delete the cookie of the site and is come back the right visual.
    thanks a lot
    i have another question but i think i need to open another thread….is this riht?
    thanks a lot again!!
    #412014
    Glad clearing the cookies worked.
    Yes, you need to open a new thread for each issue as it helps us in responding.
    John.
This topic contains 4 replies, has 2 voices, and was last updated by  John Wesley Brett 13 years, 2 months ago.
