  • nennker Friend
    #168390
    Hi read some threads about logo problems. I think my problem is different.
    in my megamenu every menu point has a different color scheme.
    I changed the css file:
    h1.logo a { background: url(../images/logo500.png) no-repeat left;
    display: block;
    height: 70px;
    width: 500px; }
    After changing the logo I have some problems:
    there is an blue line shown at the bottom of all other sites!!!
    the log is not shown completely by using the internet explorer.
    where I have to change the default color scheme (logo.png, css file)?
    http://www.nennker.de
    regards nennker
    Manos Moderator
    #411860
    Please set CSS optimization to off so i can debug this issue.
    Manos
    khoand Friend
    #411861
    I don’t understand your intension.Could you give me a snapshot with your annotation?You go to Template manager,choose JA Travel template, then change CSS Optomize fieds to NO, so I can check how and where to customize for you.
    nennker Friend
    #411862
    changed CSS Optomize fieds to NO
    Manos Moderator
    #411865
    It looks like you have added an extra color CSS value somewhere in your CSS Code
    background-attachment: scroll;
    background-clip: border-box;
    background-color: #8BA1B5; ->? you are overwriting this one
    background-image: url("../images/mainnav-bg.gif");
    background-origin: padding-box;
    background-position: left bottom;
    background-repeat: repeat-x;
    background-size: auto auto;
    Please undo this one and you will loose the blue line. Also in order for your logo to be displayed on all colors you have to change the line that calls the logo file on every color css files you can find them under /templates/ja_travel/core/themes/
    Manos
    nennker Friend
    #412052
    thanks. I fixed the problem.
This topic contains 6 replies, has 3 voices, and was last updated by  nennker 13 years, 3 months ago.
