Sjoerd de Jong Friend
Sjoerd de Jong
April 27, 2008 at 3:18 pm #127974After using JA Telline I for quite a while now, i saw JA Telline II – Superb !!!
Thanks for issuing the 1.0 version.However I can’t use the different color themes. I also can’t change the default color. I tried to change it trough alterations in the ja_vars_1.0.x.php but whatever I change the default color stays blue. (other options as logotype, logotext, ja_tool_menu are working great after I changed them in the ja_vars_1.0.x.php).
I would like to have different colors in the menu as showed in the demo.
Please help.April 28, 2008 at 4:10 am #247072Hi blackdog,
JA Teline II for joomla 1.0 version don’t support to change themes color and screen. The color only change for each session when you click top menu.Sjoerd de Jong FriendSjoerd de Jong
April 28, 2008 at 6:01 pm #247145<em>@hienmeo 50820 wrote:</em><blockquote>Hi blackdog,
JA Teline II for joomla 1.0 version don’t support to change themes color and screen. The color only change for each session when you click top menu.</blockquote>I don’t quit understand you. Das the color only changes each session you click on the top menu (also in 1.0) or isn’t there any color change in the 1.0 version?
Sherlock FriendSherlock
- 2478 times in 2162 posts
April 29, 2008 at 2:51 am #247192blackdog !
You can reade user guide for teline_ii in 4. JA ZIN PLUGIN (plg_jazin.zip) item : http://www.joomlart.com/forums/topic/ja-teline-ii-read-me-userguide/ , this section will help you have different color on menu system. User guide is wrote for 1.5 version but you can easy do it with 1.0 , it ‘s similar.Sjoerd de Jong FriendSjoerd de Jong
May 2, 2008 at 7:49 am #247541Thks for the reactions.
Yes, JA ZIN Works ! However the menu doesn’t.May 13, 2008 at 1:51 am #248867How do you change the color theme to lime in 1.5?
Please.
May 13, 2008 at 2:06 am #248873hi mariovfx !
I have replied you in http://www.joomlart.com/forums/topic/can-not-load-regular-module-as-menu-item/#post-248872 -
This topic contains 7 replies, has 4 voices, and was last updated by Sherlock 16 years, 7 months ago.
