November 24, 2011 at 7:38 pm #171064
hi,
can someone please help me about columns in ja anion. I try to put 2 columns in one category in blog layout options but its still show just
one column.thanks
pavit Moderatorpavit
November 25, 2011 at 11:11 am #426365<em>@pavit 284830 wrote:</em><blockquote>Hi techlogi1
could you send me via Private Message your admin details ?
Thanks</blockquote>
hi pavit,
thanks for reply,
I send you a messege, witing for answer.
November 25, 2011 at 11:27 am #426371You must give me the url of your backend site also
November 25, 2011 at 11:31 am #426373sorry miss that, i sent you
thanks
November 25, 2011 at 3:25 pm #426407any progress?
November 25, 2011 at 3:27 pm #426410Hi techlogi1
Could you reinstall the template using the quickstart package ?
I think it’s the easiest solution for your problems also you need to update the JaT3 Framework plugin to the latest version released
November 25, 2011 at 3:29 pm #426411i use quickstart package at first place, but I can reinstall.
thanks for advice, Ill let you know if that solve problem.
November 25, 2011 at 6:58 pm #426438I install quickstart package again with site example but now I have one more problem.
When I open site, site looks fine, but when Itry to click on something i got white page with No input file specified..and i dont know what is that where i go wrong.
November 25, 2011 at 7:41 pm #426446I change Search Engine Friendly URLs to No to solve No input file specifie problem.but still have issues with columns.
December 23, 2011 at 2:14 pm #430991I am also having problems with columns in the Anion category blog. I have the lead article set to 1 and following set to two columns but the stories are stacked one after the other. Did you resolve the problem?
This topic contains 13 replies, has 3 voices, and was last updated by techlogi1 13 years ago.
