  • ajaylulia Friend
    #171244
    hello,
    I have just bought JA Comments and facing issue with login popup, the page is not loading properly.
    Attached image contains the layout for login form. You may check the same on following link:
    http://www.kuchbhi.com/Health/how-to-treat-minor-injuries.html
    Regards,
    1. sitepost
    jooservices Friend
    #427271
    I guess you have php error ( but do not display ).
    May i have your FTP / backend access for checking and fix it ?
    Thank you,
This topic contains 2 replies, has 2 voices, and was last updated by  jooservices 13 years, 1 month ago.
