January 31, 2007 at 12:07 pm #118574
<em>@khanh 7232 wrote:</em><blockquote>Hi all,
We are working to update JA News module. We will release the update version in 1 or 2 days.Thank you very much for reporting bugs.</blockquote>
Hi Khanh.
although you have said it (“u will release the update version…”), the new ja-news runs ok with mozilla 1.5.0.9 and mozilla 2.0, but have a problem with explorer 6 (acess denied). See atachment or visit amberescomputers.es with IE6.I has downloaded the ja-news module this morning and upload again, and this has solved the problem with mozilla.
January 31, 2007 at 12:10 pm #213936<em>@muyay0 7248 wrote:</em><blockquote>Hi Khanh.
although you have said it (“u will release the update version…”), the new ja-news runs ok with mozilla 1.5.0.9 and mozilla 2.0, but have a problem with explorer 6 (acess denied). See atachment or visit amberescomputers.es with IE6.I has downloaded the ja-news module this morning and upload again, and this has solved the problem with mozilla.</blockquote>
i forget the atachment
ha le-viet Developerha le-viet
- April 2006
- 5 times in 1 posts
- April 2006
February 1, 2007 at 2:17 am #213959Hi muyay0,
I’ve tested your site with the URL http://www.amberescomputers.es in IE6 and the roller was working. If you tested the site without the www, it might not work.
To make your site always have www, go to your hosting control panel I thought there will be an option to set. Ask your hosting provider for more information.
Regards,
Ha Le-Viet.February 1, 2007 at 7:29 am #213967Hi again.
Thanks Ha Le-Viet. I have tested on another Pc with IE6 and it work ok :confused: . Cokkie problems:confused: :confused: ? I dont understand the reason of this :(.
Well, the problem has been solved… now i´ll try to solve on my IE6 Browser.Thanks a lot.
DavidAuthorPostsViewing 5 posts - 1 through 5 (of 5 total)This topic contains 5 replies, has 2 voices, and was last updated by David 17 years, 11 months ago.
[Common problem] AJAX worked on www.mysite.com but not mysite.com
