  • tarasiadis Friend
    #126749
    Are these modules compatible with joomla 1.0.15? I tried to install in joomla 1.0.15 and I see the erro message:
    ERROR: Could not find a Joomla! XML setup file in the package.
    Installation file not found:
    /home/user/public_html/site/media/install_47e14776b9602/
    #242595
    seem you install extension file, you must unzip extension file, and you will see all module .zip. plz install them
    tarasiadis Friend
    #242597
    No, I don’t install extenstion file. I download the first and the last file from the list of downloads (http://www.joomlart.com/forums/downloads.php?do=cat&id=20)
    It is one zip only.
    tarasiadis Friend
    #242685
    Somebody to tell me which version of modules I could use at joomla 1.0.15 please.
    Thanks.
    #242710
    I’ve checked that link, that module is module for joomla 1.5, so you will have error when install it. I will talk to JA update that module tomorrow. Plz wait
    #242733
    tarasiadis Friend
    #242813
    Thanks! But the module JA Newsmoo module for JA Justicia (the last file) still doesn’t installed. Is there any version of this module for joomla 1.0.15.
    #243001
    Can you pm for me account admin of your site? I will install that module for you.
    #243048
    Hi.
    Now you can test again your site, I install mod_ja_newmoo, and mod_ja_newslight is still okie in your site.
    Glad to can help you.
    Tung
This topic contains 9 replies, has 2 voices, and was last updated by  Sherlock 16 years, 9 months ago.
