  • neurdenburg Friend
    #138022
    Anyone having trouble installing components under the Joomla 1.5.9 Pyrite Quickstart package?
    The installation of the package itself went fine. Did all the usual things:
    – setting directory permissions
    – configuring ftp layer
    – check tmp directory path in config.php
    The following happens:
    From the admin install interface I point to the component install zip file and click install. After a while the page reloads to /administrator/index.php but is completely blank. When I reload again It will load the admin menu startpage but nothing appears to have happened. No feedback about the installation whatsoever.
    I can see on the server that it has uploaded some files and folders to both the administrator/components and /components directory, however no new component menu entry shows up under ‘components’ in the admin menu.
    I have tried several different components and even made a completely new installation on a different server but the same thing happens!
    Server info: FreeBSD 7.0-RELEASE-p4
    MySQL version: 5.0.67
    Php: 5.2.6
    Apache 1.3.41
    Memory (24Meg)
    Anyone have any suggestion?
    Anonymous Moderator
    #290849
    I think this issue from the media folder. This folder and its files are not exist.
    neurdenburg Friend
    #290907
    Thanks for the suggestion but that was not the issue. I do have the media folder and the permissions where set correct.
    However this morning I managed to overcome the issue by turning of the FTP layer. Apparently there is some problem with that. Now extensions install correctly again!
    Thanks anyway!
This topic contains 3 replies, has 2 voices, and was last updated by  neurdenburg 15 years, 10 months ago.
