  • austjamesl Friend
    #168151
    I am using the JA Community Plus Template with Joomla v1.6 and I receive the following errors when filling out ALL fields on the Contact Form:
    Field required: Name
    Field required: Email
    Field required: Subject
    It appears as though validation is occurring incorrectly.
    I have found another thread on Joomlart with the same issue, however the solution is not published: http://www.joomlart.com/forums/topic/contact-form-problem-3/
    Any assistance would be much appreciated.
    Jamess
    #410909
    Hi Jamess,
    This issue probably belong to the HTML Override section of the JA Community Plus Template for the com_contact, i reported it to our developers for checking on and fix it then, you can also tracking the issue status in here http://pm.joomlart.com/browse/JATCCOMMUNITYPLUSJIVI-147
    To know when it is fixed !
    austjamesl Friend
    #411096
    Thank you. I will keep an eye on it.
    As this is the contact us form which is quite an important function, can you please advise when you expect this issue to be resolved?
    James
    austjamesl Friend
    #411970
    A little help please?
    James
    #412120
    Hi Jamess,
    This issue has been fixed , please try as below to get it fixed in your site
    backup the file of templatesja_community_plushtmlcom_contactcontactdefault_form.php
    unzip my attchment file then put it there to replace the backup file
    1. default_form.zip
This topic contains 5 replies, has 2 voices, and was last updated by  Sherlock 13 years, 3 months ago.
