Could you clarify the problem when enabling it? you can show me steps by steps to replicate the issue so that I can check for you.
I have now enabled captcha, sometimes the mails are not delievered and the form doesn’t react when entering Captcha code
You can use our JA Multiple Captcha Engine plugin instead of default Captcha of Joomla.
Please take a BACKUP of your site first and download attached file then install into your site
I used this engine , but same problem
Which email service you use to test this contact form and it doesn’t work? I tried to test many times but it works properly.
Also try to check the SPAM mail box to see whether email go there or not.
This topic contains 21 replies, has 2 voices, and was last updated by Saguaros 9 years ago.
