  • frankmiao Friend
    #1021383
    Can anyone help me to solve the following problem: container tabs module becoming narrower than normal and horizontal and vertical bars appear. Waiting for solutions. Thank you.
    Pankaj Sharma Moderator
    #1021495
    I fixed the problem directly on your site by increase the width of module position 5 from template options > Layout > responsive layout.
    Kindly check the site now.
This topic contains 1 reply, has 2 voices, and was last updated by  Pankaj Sharma 7 years, 8 months ago.
