  • gossy Friend
    #127971
    when I am click on article title it is not opening, link is ok but why it is not opening, anyone can give me solution, make it perfect?
    #247067
    Hi bluezeal !
    You can fix it by way :
    open application.php file in modulesmod_ja_contentslidemod_ja_contentslide folder :
    find code line at about line 111 :
    $link = JRoute::_( 'index.php?option=com_content&task=view&id='. $contn->id . $Itemid );
    change it to :
    good luck !
    manilo Friend
    #262898
    <em>@hainn84 50814 wrote:</em><blockquote>Hi bluezeal !
    change it to :
    good luck !</blockquote>
    hello hainn84
    i need your performance !
    i install quick ja genista, but inside windows of contentslide i can read this message “Warning: require_once(/modules/mod_ja_contentslide/includes/defines.php) [function.require-once” ,and i see only one pic.
    can you help me ?
    very thank !
    #262959
    Hi manilo !
    Please send url of your site , i will help you.
    manilo Friend
    #262992
    <em>@hainn84 70410 wrote:</em><blockquote>Hi manilo !
    hello dear
    http://www.riccione.sm/
    i need to close the site for maintenance, i open for you..
    thank for your fast message
    #263133
    Hi manilo !
    Please publish contentslide or Please send admin acc via pm , i will check it for you.
    #263187
    Hi manilo !
    Please check again ! Ja contentscroll is ok now .
    manilo Friend
    #263201
    <em>@hainn84 70716 wrote:</em><blockquote>Hi manilo !
    Please check again ! Ja contentscroll is ok now .</blockquote>
    ooo dear !!
    fantastic!! compliment !! very good
    that is real show
    thaks for all
    can you tell me where was the problem ?
    see you later
    #263319
    Hi manilo !
    The problem is content for jasontentscroll missing images. you must add image for it ,
    manilo Friend
    #263348
    <em>@hainn84 70893 wrote:</em><blockquote>Hi manilo !
    The problem is content for jasontentscroll missing images. you must add image for it ,</blockquote>
    ok ok ok !
This topic contains 10 replies, has 3 voices, and was last updated by  manilo 16 years, 4 months ago.
