  • bwls Friend
    #1091078
    I have altered the template files to enable Content Mass Top position But it is not displaying on top of the default article and I do not know why. The site is http://www.keyfunds.com
    William Slaughter
    https://jdevtech.com
    847-942-4265
    Hi William,
    You need to put the snippet of code which renders modules in content-mass-top position above the ‘component’ block like this: http://prntscr.com/icp4qt
    I updated it in the PHP file: root/templates/ja_edenite_ii/tpls/blocks/mainbody/one-sidebar-left.php for you and it’s showing fine now.
    Cheers!
This topic contains 1 reply, has 2 voices, and was last updated by  Saguaros 6 years, 10 months ago.
