  • asolellop Friend
    #190713
    I do not see the position content-mass-top in the template JA University. To which may be due?
    Working locally so I can not provide a link.
    Did you verified that your default layout middle block name is set as showed here ?
    <blocks name="middle" colwidth="40">
    <block name="content-mass-top">content-mass-top</block>
    <block name="right1">position-7</block>
    <block name="right2">position-5</block>
    </blocks>
    To verify it go to extensions >> Template manager >> JA Univeristy – Default >> Layouts Tab >> Default layout
    asolellop Friend
    #506365
    Yes, I checked and is correct as you said. Another solution?
    I am attaching the code
    <?xml version=”1.0″ encoding=”utf-8″?>
    <layout name=”desktop”>
    <!–Extra css load for this layout–>
    <stylesheets>
    <file>css/template.css</file>
    <file media=”only screen and (max-width:719px)”>css/layout-mobile.css</file>
    <file media=”only screen and (max-width:479px)”>css/layout-mobile-port.css</file>
    <file media=”only screen and (min-width:720px) and (max-width: 985px)”>css/layout-tablet.css</file>
    </stylesheets>
    <blocks name=”top” style=”xhtml”>
    <block name=”absolute” type=”modules” style=”raw”>absolute</block>
    <block name=”top-panel” type=”modules” style=”raw” main-inner=”1″>top-panel</block>
    <block name=”header” type=”header” main-inner=”1″></block>
    <block name=”mainnav” type=”mainnav” main-inner=”1″></block>
    <block name=”cpanel” type=”usertools/cpanel”></block>
    <block name=”masshead” style=”raw” no-main=”1″>masshead</block>
    <block name=”slideshow” style=”raw”>slideshow</block>
    <block name=”topsl” type=”spotlight”>user1, user2, user3, user4</block>
    <block name=”topsl1″ type=”spotlight”>user5, user6, user7, user8</block>
    <block name=”topsl2″ type=”spotlight”>user9, user10, user11, user12</block>
    </blocks>
    <blocks name=”middle” colwidth=”40″>
    <block name=”content-mass-top”>content-mass-top</block>
    <block name=”right1″>position-7</block>
    <block name=”right2″>position-5</block>
    </blocks>
    <blocks name=”bottom” style=”xhtml”>
    <block name=”botsl” type=”spotlight”>user13, user14, user15, user16</block>
    <block name=”botsl1″ type=”spotlight”>user17, user18, user19, user20</block>
    <block name=”botsl2″ type=”spotlight”>user21, user22, user23, user24</block>
    <block name=”navhelper” type=”navhelper”></block>
    <block name=”footer” type=”footer”></block>
    </blocks>
    </layout>
    nubtech24 Friend
    #506643
    <em>@pavit 390100 wrote:</em><blockquote>Hi
    </blocks>
    To verify it go to extensions >> Template manager >> JA Univeristy – Default >> Layouts Tab >> Default layout</blockquote>
    Hi I have the same problem and I can also see the above lines same as what you have copied but still can’t see content mass top position but can see position-5 & 7
    phong nam Friend
    #506659
    Hey guys,
    It is our mistake in showing defined positions on our JA University template. You can fix this issue by openning templatesja_universitytemplateDetails.xml file, the put below line before </positions>:
    <position>content-mass-top</position>
    Clear JAT3 cache after applying changes. Then you can select the content-mass-top in position selection list of module backend.
    asolellop Friend
    #506702
    Ok! Soldev
    nubtech24 Friend
    #506784
    thanks! got it sorted!
    wldnls Friend
    #507182
    Hi Leo,
    I had the same issue below. I fixed it with your suggestion of <position>content-mass-top</position>,
    but the content in a module in content-mass-top still isn’t showing in the homepage.
    anything else you recommend I should do?
    phong nam Friend
    #507232
    Hi wldnls,
    You can check out the menu item that your content-mass-top module is assigned to.
    In case, this is not effective, you can send me PM, i will help you to check this issue.
    newwebsi Friend
    #514157
This topic contains 10 replies, has 6 voices, and was last updated by  newwebsi 10 years, 11 months ago.
