  • turgut Friend
    #130994
    hello
    I have a problem that all contents are comes out as moved to the right rather than being inline with the edge of main menu when a submenu click to display them. The site is here http://www.cierrarecycling.com. Anybody has any suggestion to fix it.
    Turgut
    Menalto Friend
    #260563
    You have added the code to google analystics in left module position. Remove it from there and add it at the bottom of the template instead maybe?
    turgut Friend
    #260566
    Thnak you!
    Turgut
    turgut Friend
    #260569
    but now I have a bit large space at the bottom when I put google analystics at the debug module position. what do you suggest.
    Menalto Friend
    #261126
    Do you have any successful ?
    Menalto Friend
    #270438
    did you manage to get this solved? if you did please mark this as solved, if you still have problems please post here again.
This topic contains 7 replies, has 3 voices, and was last updated by  Menalto 16 years, 4 months ago.
