  • meioaereo Friend
    #148064
    Hi guys. As you can see in the image below I am having that problem when I add an image gallery. The plugin is configured correct but it seems that the alignment is not ok. I have a few images and they appeared stacked on top of each other. I am sure that the plugin is ok, it must be something with the content alignment for the template.
    Any help?
    Phill Moderator
    #330473
    Please provide a link to your site so we can take a look
    meioaereo Friend
    #330475
    <em>@phill luckhurst 162062 wrote:</em><blockquote>Please provide a link to your site so we can take a look</blockquote>
    Here is the link:
    http://dfall.com.br/aerotdfinal/index.php?option=com_content&view=article&id=172&Itemid=64
    There are about 24 images. I have used thet plugin before so many times with other templates just to make sure that the problem is not with the plugin.
    Thank You
    Phill Moderator
    #330486
    Looks like a bug in that it is not pickin up on the image size when lightbox is applied. I’ve not time this eve to look at it so if you need a fast response you should raise a ticket.
    heldholgi Friend
    #330491
    Hi all,
    I have the same problem while testing this template.
    Site: http://ixeus.de
    Thanks for help joomlart !
    meioaereo Friend
    #330632
    Hey guy, I got this from support team and worked for me:
    Open plugins/content/plg_jathumbnail/style.css
    Find
    .thumbnail {
    left:0;
    position:absolute;
    top:0;
    z-index:1;
    Remove or comment off this css code.
    Thank You Joomlart
    heldholgi Friend
    #330716
    <em>@meioaereo 162260 wrote:</em><blockquote>Hey guy, I got this from support team and worked for me:
    Find
    .thumbnail {
    left:0;
    position:absolute;
    top:0;
    z-index:1;
    Thank You Joomlart</blockquote>
    i removed the code but it doesn’t work !
    Any other ideas ?
This topic contains 7 replies, has 3 voices, and was last updated by  heldholgi 14 years, 11 months ago.
