  • aryentain99 Friend
    #200011
    Hi guys, my proyect with Mitius Magazine is heading for completion! and i have this new little question: i would like to show the content slider module like the “latest games” in the demo (placed in “position 3”) in my position 5 (the right column) but the style doesn’t remain the same once i publish it in that position, specially the arrows and the article “inner box” in different sizes and margin, is there any way to have the same style like the module when is placed in position 3, but in position 5 without altering any other module already placed in that position? Here you have my example
    http://www.arquespalacio.com.ar/saracatu/index.php/fans/fan-eventos#year=2014&month=7&day=26&view=month
    Thanks in advance!
    Ninja Lead Moderator
    #543602
    I have compared both css styles to work with JA ContentSlider module in position-3 and position-5. The only difference is of button icon in right top module
    If you want to change it please make changes in css style
    Open templates/ja_mitius/css/mod_jacontentslider.css file
    Change
    .ja-contentslider-right,
    .ja-contentslider-left {
    background-image: url(../images/button-nav.png);
    background-repeat: no-repeat;
    cursor: pointer;
    display: inline-block;
    width: 30px;
    height: 30px;
    To
    background-image: url(../images/button-nav-vertical.png);
    cursor: pointer;
    width: 30px;
    height: 30px;
    aryentain99 Friend
    #543797
    Many thanks Ninja, that made the trick! About the margin in each title, it seems when you have a three line tittle the margins have that problem, take a look:
    1. modulomargenes
    #543880
    <em>@aryentain99 438605 wrote:</em><blockquote>Many thanks Ninja, that made the trick! About the margin in each title, it seems when you have a three line tittle the margins have that problem, take a look:
    </blockquote>
    I have raised this bug to development team here. They will check and fix this bug.
    cssyeah Moderator
    #544374
    I have just checked this issue on your site. The reason is the height property of each item, if you view HTML source code you will see item’s height is 100px and position of each item is absolute. So if you increase spacing between two items you should increase height property of each item.
    You can configure it in the back-end of the JA Content Slider module. I suggest you increase to about 110px.
    aryentain99 Friend
    #545077
    i’ve tried to change the div height at the backend to several numbers like 110, or even 150 but it doesn’t solve the issue.
    #545463
    <em>@aryentain99 440172 wrote:</em><blockquote>i’ve tried to change the div height at the backend to several numbers like 110, or even 150 but it doesn’t solve the issue.</blockquote>
    I saw the title of the module has a lot of characters and they overlap together. In this case, I suggest you add a function to limit the character in the title.
    + Open templates/ja_mitius/html/mod_jacontentslider/default.php file
    Change
    defined('_JEXEC') or die('Restricted access');
    To
    if(!function_exists(cut_string)) {
    function cut_string($title, $max)
    if($title!=''){
    if(is_array($title)) list($string, $match_to) = $title;
    else { $string = $title; $match_to = $title{0}; }
    $match_start = stristr($string, $match_to);
    $match_compute = strlen($string) - strlen($match_start);
    if (strlen($string) > $max)
    if ($match_compute < ($max - strlen($match_to)))
    $pre_string = substr($string, 0, $max);
    $pos_end = strrpos($pre_string, " ");
    if($pos_end === false) $string = $pre_string."...";
    else $string = substr($pre_string, 0, $pos_end)."...";
    else if ($match_compute > (strlen($string) - ($max - strlen($match_to))))
    $pre_string = substr($string, (strlen($string) - ($max - strlen($match_to))));
    $pos_start = strpos($pre_string, " ");
    $string = "...".substr($pre_string, $pos_start);
    if($pos_start === false) $string = "...".$pre_string;
    else $string = "...".substr($pre_string, $pos_start);
    else
    $pre_string = substr($string, ($match_compute - round(($max / 3))), $max);
    $pos_start = strpos($pre_string, " "); $pos_end = strrpos($pre_string, " ");
    $string = "...".substr($pre_string, $pos_start, $pos_end)."...";
    if($pos_start === false && $pos_end === false) $string = "...".$pre_string."...";
    else $string = "...".substr($pre_string, $pos_start, $pos_end)."...";
    return $string;
    }else{
    return $string ='';
    + and call it drops text in title
    Find and change
    <?php if( $params->get( 'showtitle' ) ) { ?>
    <div class="ja_slidetitle">
    <?php echo ($params->get( 'link_titles' ) ) ? '<a href="'.$link.'" title="">'.$contn->title.'</a>' : $contn->title;?>
    </div>
    <?php } ?>
    To
    <?php echo ($params->get( 'link_titles' ) ) ? '<a href="'.$link.'" title="">'.cut_string($contn->title,15).'</a>' : cut_string($contn->title,15);?>
    </div>
    <?php } ?>
    Let me know if it helps
    aryentain99 Friend
    #547026
    Thanks Ninja, that seems to work, but i need to change the number of characters, since they look cropped too short:
    which var do i have to change to make it a bit longer?
    And i have this question: is it possible to apply this function to the breadcrums? Since long routes seem to continue in a second line too far fron the module area. thanks in advance.
    1. near
    #547120
    As my posted above you will see code as
    and you can change my red mark from 15 to 30 or more to suit your needs
This topic contains 9 replies, has 3 voices, and was last updated by  Ninja Lead 10 years, 4 months ago.
