farquhar Friend
farquhar
- November 2008
January 12, 2010 at 2:45 pm #147582After installing the quick-start Mona package, there seems to be some differences with the demo.
The shadow captions effects do not appear in front-page contentslider and not in the article images in fp as in content.
If I remove the ‘Sample Image’ title the whole shadow effect disappears in article image.
Is this a (known) editor issue as well?BTW: Both template.css and contentscroll.css code in the demo are slightly different from the css codes in the quickstart package.
Tried and tested these different CSS variations, with no result. Searched the forum, seems I’m not the only one.. but did not see/found a solution.
Tried also the suggestions of JA Developer as mentioned in the Mona forum. Tested on both Mac (Safari,FF And Opera) as on Vista (IE’s And FF) with same results.
Hosted and tested on Linux/Apache (PHP 5.2.11) which carries more Joomlart 1.15 based templates/sites (with no problems).-
Anonymous Moderator
JA Developer
- 2008 times in 1700 posts
January 13, 2010 at 10:33 am #329205The shadow captions effects do not appear in front-page contentslider
This module does not support the caption for image.
farquhar Friendfarquhar
- November 2008
January 13, 2010 at 11:12 am #329209So, how is it done than within the demo?.. There is a shadow effect, unlike the Quickstart
January 15, 2010 at 10:51 am #329373Hi farquhar
It is the caption of article. We don’t filter this option into our module.
In your administrator, you only add a caption to each article, it will show on the frontpage
- November 2008
January 15, 2010 at 11:22 am #329375<em>@JA Developer 160529 wrote:</em><blockquote>Hi farquhar
In your administrator, you only add a caption to each article, it will show on the frontpage</blockquote>
pm-ed u…….Anonymous ModeratorJA Developer
January 18, 2010 at 2:59 am #329580Hi farquhar
I have checked your website and saw that it is like our demo site. I don’t find any issue in your website
- November 2008
January 18, 2010 at 1:45 pm #329631Again, there is in my opinion a difference (cynical now!, after a week awaiting a reaction).
Take a look at difference in the content slider and pic in the articles: No shadow effects!!!
(and its not just a issue to put a caption to the articles)Also there is a difference in both CSS from the demo and in the QS!!
January 20, 2010 at 2:11 am #329798Hi farquhar
Please open templates/ja_mona/css/template.css file, at about line 125, find following code section:
.img_caption p {
color:#757575;
display:none;
margin-top:0;
padding-top:5px;
text-align:center;
}and change to:
.img_caption p {
color:#757575;
margin-top:0;
padding-top:5px;
text-align:center;
}farquhar Friendfarquhar
- November 2008
January 20, 2010 at 9:26 am #329843Hi JA developer,
Did that before, wich will create twice the shadow effect. Notice there are more differences within the CSS of the demo and QS!!:
Updated the media/system/js/caption.js file. Which managed to get rid of the the title within the shadow effects in the blog articles as mentioned before (see pics).
Meanwhile also got the shadow effect in the content slide items, Only not (yet, I hope..) the effects in the articles of the slider.Suggest U make a clean QS installation first, to test, you’ll see the trouble.
- November 2008
January 20, 2010 at 10:25 am #329847Figured it out:
The caption/alignment was overwritten with a float left. (known editor issue?.. Which didn’t cross my mind..)
After updating the media/system/js/caption.js file before (to solve the blog caption issue as mentioned before)Also to get a neat layout, added to template CSS (as in the demo) line 145:
div.article-content img,
.img-desc img {
border: 1px solid #FFFFFF;
padding: 4px;to:
.img-desc img {
margin:0 8px 0 0;
padding: 4px;BTW: So don’t add caption and align with the (TinyMCE or JC) Editor! The alignment is mixed up with a ‘floated’ instead correct clean align tag.
To insert images on an article just add “align left” attribute to image tag and also add caption with the image button.For now it looks the same as the demo!
Viewing 10 posts - 1 through 10 (of 10 total)This topic contains 10 replies, has 2 voices, and was last updated by farquhar 14 years, 7 months ago.
