  • tracybezner Friend
    #146572
    Thank you for pointing out which module the “About Us” box is on the Kyanite II template.
    I realize now that the reason I hadn’t figured that out is the mod_custom module did not install for some reason on my localhost.
    I’ve done two re-installs of Joomla 1.5.15, and two re-installs of the Kyanite II template each time I’ve re-installed.
    I’ve also tried to install the module now about 30 times with no success.
    Any ideas?
    hmm
    Why do you use the quickstart to complete your site? I think that nothing problem happen as you said 🙂 if you would you like
    kimberley Friend
    #345374
    i just relise at i dont have mod_custom module in my administrator also. i have doen the quickstart.
    any ideas how enable mod_custom module?
    Warm regards Kimberley
    Dear Kimberley!
    I think you click the “New” button in the module manager, you try to find a module named is “Custom HTML“, if the site has not this, i think you should re-install the site
    kimberley Friend
    #345668
    i will lose all my changes i have been doing for month. it will take me days to do all the changes again.
    please give me another alternative!
    regards K
    Dear kimberley!
    I really i could not know exactly about whats happening on your site: the site has not the custom module or how?
    <blockquote>
    </blockquote>
    I think that you give me the link to your site and the administrator account via the Ticket CDA-211338.
    i ‘ll check this in detail
    Thanks so much
    filmlover7 Friend
    #368193
    Many Many Many people are complaining about the same issue… NO CUSTOM MODULE is installed on the new Teline iii V2 “quick” start.
    PLEASE tell us how to simply get the module without having to loose all our work. Can JoomlArt team please help with this…. or another user perhaps.
    Thank you.
    (we are a little frustrated by the “new… Improved” template. )
    COMPONENTNOTINSTALLED is what shows up when we try to create NEW Module based on “Custom HTML”
    Phill Moderator
    #368195
    That is strange as I cannot replicate. I’ve just created a new mod_custom using teline3v2 v1.0.0 on my local testbed.
    If you look at the demo content in the quickstar you will see that mod_custom gets used a number of times for that content so I cannot see how it cannot be installed.
    filmlover7 Friend
    #368335
    <em>@filmlover7 210343 wrote:</em><blockquote>Many Many Many people are complaining about the same issue… NO CUSTOM MODULE is installed on the new Teline iii V2 “quick” start.
    Thank you.
    COMPONENTNOTINSTALLED is what shows up when we try to create NEW Module based on “Custom HTML”</blockquote>
    THE CAUSE OF THIS SEEMS TO BE THAT WE HAD THE “LEGACY” OPTION ON, SO IT INTERFERED WITH FUNCTIONALITY OF Tiii v2.
    Now it works.
    Thanks.
    Phill Moderator
    #368336
    I find that strange as I still cannot replicate this.
This topic contains 10 replies, has 5 voices, and was last updated by  Phill 13 years, 11 months ago.
