  • chiman Friend
    #132604
    I’ve implemented the ‘avreloaded’ plugin on my Teline II based website but I’m unable to get any of the controls to come on, e.g., full screen mode, and I can’t increase the width of the rectangle used to display the streaming video. Right now it’s a square bu we’re looking for more of a rectangle.
    Here’s the site: http://www.kenovaprojects.com/projects/cfl/
    Thank you in advance for any assistance you can provide.
    Cheers James, on behalf of Chiman.
    #267324
    Hi chiman !
    you can control width and height of it in admin :
    – YOu go to admin >> extensions >> module manager >> video module
    – On right panel you can width and height value.
    gaygiorgia Friend
    #267349
    you can work on media code too to obtain a major height 🙂
    chiman Friend
    #267976
    <em>@hainn84 75916 wrote:</em><blockquote>Hi chiman !
    – On right panel you can width and height value.</blockquote>
    Hi Hainn84 and gaygiorgia:
    Thank you for your responses!
    Using the following settings I was able to achieve the results I was hoping for. Thank you for your guideance:
    {youtubejw width=”329″ height=”280″ searchbar=”false” plsize=”0″ stretch=”true”} ID {youtubejw}
    Cheers, chiman
This topic contains 4 replies, has 3 voices, and was last updated by  chiman 16 years, 3 months ago.
