tversover Friend
tversover
- March 2009
June 11, 2009 at 1:17 am #141846Hi!
My website won’t show correctly in Internett Explorer. A get the message “Internet Explorer Cannot Open the Internet Site Operation Aborted”. It’s not good in IE8.0, but in 7.0 and older it’s horrible.
I’m trying to find out why. Could it be that the newsletter component Commucator that I installed messes things up? Have anyone had problems with that?
Thanks!
jsliao Friendjsliao
- April 2008
- 236 times in 210 posts
June 11, 2009 at 1:54 am #307594well to confirm, try disabling or deleting the component and see if your site works?
floo Friendfloo
- October 2008
- 8 times in 4 posts
June 17, 2009 at 6:42 pm #308210I opened your website in both, firefox and IE 7, i did not encounter any problems. Did you changed the module ?
Proof :
tversover Friendtversover
- March 2009
June 18, 2009 at 3:07 am #308249The thing is that the text under the image is gone. It only show some words from the original text. Do you know what it could be?
questbg Friendquestbg
- May 2008
- 339 times in 197 posts
June 18, 2009 at 4:04 am #308250Check the article for any strange ‘code’ that shouldn’t be there. Click the HTML tab and see if there’s any code that looks odd and remove it. This can occur if the text has been pasted into the Article Editor (especially if it’s come from Word).
sunrise Friendsunrise
- February 2007
- 166 times in 114 posts
June 18, 2009 at 6:18 am #308255At lease in firefox it looks fine.
Netsiden ser fin ut og det er fint å se hva som skjer i Norge. Jeg håper du får til det du trenger. Lykke til.
mj1256 Friendmj1256
- June 2007
- 225 times in 118 posts
June 18, 2009 at 2:31 pm #308305Quest is right
did you copy and paste any content intop the site, that is probably the issue as word and other applications have proprietary code that does not work on websites.
also, look for any unopened or unclosed div and P tags in your content
- March 2009
June 19, 2009 at 2:37 pm #308440I deleted the Communicator and the subscibe-exstension last week, and the site started to work a bit better. But yesterday I reinstalled it, and now the website won’t open at all in IE 7. What could be the problem?
Thanks!
- March 2009
June 23, 2009 at 4:35 pm #308832It seems like the Communicator newsletter extension is the problem. I just want to delete it. The problem is that it is really handy. Do you know of any other good “subscribe to newsletter-tools”?
Thanks.
This topic contains 9 replies, has 6 voices, and was last updated by tversover 15 years, 6 months ago.
