woodsworks Friend
woodsworks
- October 2013
- 3 times in 1 posts
January 29, 2014 at 1:12 pm #194230Hi there sorry for creating a new topic,
but it’s really urgent for me.
the objective is to create a block or a layout where I will put a full screen slider with width:100%
ja-pursite
has some div structure like this:
<div id=ja-header>
<div id=ja-slider>As you can see, there are too many div container on my slider module, and each one has some padding, or margin properties, theses properties are make full screen impossible,
Which means I will break container’s width definition.
Please help, i’m looking for solutions for 2 days…. not working….:((
I include my website info, on this thread, you can check everything freely.
TomC ModeratorTomC
- October 2014
- 3155 times in 2495 posts
January 29, 2014 at 4:15 pm #520383Were the steps you took to try to create your new position similar to the steps outlined wihtin THIS TUTORIAL?
woodsworks Friendwoodsworks
- October 2013
January 29, 2014 at 4:23 pm #520388<em>@TomC 408379 wrote:</em><blockquote>Were the steps you took to try to create your new position similar to the steps outlined wihtin THIS TUTORIAL?</blockquote>
Thanks Tom but I didn’t found the mainbody.php in the folder : /template/ja-pursite/blocks/:((
phong nam Friendphong nam
- May 2015
- 974 times in 888 posts
January 30, 2014 at 10:18 am #520501@woodsworks: All blocks of Puresite template are defined within the .main container with fixed width as you saw. In order to get slideshow full width, you can simply put below override css rules into the end of /templates/ja_puresite/css/template.css file:
#ja-slider .main {
width: 1350px;
max-width: 1500px;
}#ja-slider div.ja-slider img {
width: 100%;
Clear JAT3 cache after updating changes.
AuthorPostsViewing 4 posts - 1 through 4 (of 4 total)This topic contains 4 replies, has 3 voices, and was last updated by phong nam 10 years, 11 months ago.
Create a block between header and body to put a full screen slider
