  • jan007 Friend
    #756382
    Template not showing properly in Safari and Microsoft Edge. It looks ok In Chrome and FireFox. I did not check other browsers.
    Microsoft Edge: The color mask is not showing (it appaers to be in the backround)
    Safari (PC): The masshead image is cut in half..
    Adam M Moderator
    #756614
    Hi @jan007,
    Thanks for your report, I raised an issue which you can check here so our development team can investigate the problem and fix it asap, please stay tuned.
This topic contains 2 replies, has 2 voices, and was last updated by  Adam M 9 years ago.
