  • tread77 Friend
    #165175
    Three things:
    1. Using the widget on my events page adds a scroll bar along the bottom horizontal.
    2. When I click on the widget the pop-up box will not let me submit anything.
    3. I would like my installation to look just like your demo. Is there a way I can make the JA CSS the default?
    Stork11 Friend
    #397593
    For your first problem, I checked your site and didn’t this problem. As you see in my attached screenshot, there is no horizontal scroll bar at the bottom of page.
    For your second problem, I inserted “global $javconfig;” before line “$Itemid = JRequest::getInt(‘Itemid’);” in “/components/com_javoice/views/items/tmpl/widget_search_result.php” file and the problem is resolved.
    For your third thing, I’d like to tell you know that the our demo site used JA Edenite template. It’s not a JA Voice template default.
    Best regards.
This topic contains 2 replies, has 2 voices, and was last updated by  Stork11 13 years, 5 months ago.
