Viewing 15 posts - 1 through 15 (of 16 total)
  • dnx Friend
    #1035189
    Block: Spotlight 3
    Browser: Safari 10.1
    In JA Builder and JA Builder Preview:
    <div class="animated  bounceInRight" style="min-height: 199px; opacity: 1;" data-animated-type="bounceInRight"><div class="jub-contents      z-depth- shape-square has-border-area  border-gray-lighter  " style=" border-width: 3px; border-style: solid;border-color: border-gray-lighter;   ">
    <div class="jub-element jub-element-text text-center  lead spacing-top-md spacing-bottom-md">
    <h6 class="jub-h6  " data-placeholder="text">KEY FEATURE 1</h6>
    </div>
    <div class="jub-element jub-element-text text-center   spacing-bottom-md">
    <p class="jub-p  " data-placeholder="text">Lorem ipsum dolor sit amet, consectetur adipiscing elit. Curabitur ut consectetur ipsum, tincidunt hendrerit lectus.</p>
    </div>
    </div></div>
    Note: style="min-height: 199px
    In public preview (not logged in)
    <div class="animated  bounceInRight" style="min-height: 339px; opacity: 1;" data-animated-type="bounceInRight"><div class="jub-contents      z-depth- shape-square has-border-area  border-gray-lighter  " style=" border-width: 3px; border-style: solid;border-color: border-gray-lighter;   ">
    </div>
    </div>
    </div></div>
    Note: style="min-height: 339px
    dnx Friend
    #1035195
    The Guests can’t see the edit mode of your site, not quite sure what is the matter is as I see your frontend looks fine now.
    dnx Friend
    #1035303
    dnx Friend
    #1035369
    dnx Friend
    #1035400
    dnx Friend
    #1035401
    Are you working on your site? the login info doesn’t work now btw.
    dnx Friend
    #1035929
    It seems doesn’t work, could you check and send me again?
    dnx Friend
    #1036203
    Are you able to see the site at all?
    After much testing. The problem occurs on any page with animation on the Spotlight 3 items. When the page is first loaded it displays correctly, then when it is refreshed/reloaded the min-height changes introducing the large space under each block. This happens in Safari desktop and iOS.
    dnx Friend
    #1036204
    dnx Friend
    #1036215
    dnx Friend
    #1036300
    dnx Friend
    #1036392
This topic contains 15 replies, has 2 voices, and was last updated by  Saguaros 7 years, 7 months ago.
