  • robnob Friend
    #177332
    I am having an issue on my homepages slideshow and i was hoping someone that is good with firebug can give it a shot.
    I am using a slideshow on the homepage and the margin to the left is too much. I’ve tried to figure out where the extra margin is coming from because on every other page on my site i don’t have it there.
    See image
    my site is: big3fantasy.com
    Thank you! 🙂
    1. imagehelp
    robnob Friend
    #454364
    anybody?
    only 7 views? is everyone working on JA Wall? 😀
    swissa Friend
    #454368
    <em>@robnob 321437 wrote:</em><blockquote>anybody?
    only 7 views? is everyone working on JA Wall? :D</blockquote>
    Nah, some of us are running about ruining other people’s websites! 😀
    You’re next!!
    Go to
    .ja-mass-top {
    • padding-top: 10px;
    • padding-left: 10px; <try commenting this line out
    like so
    .ja-mass-top {
    • /* padding-left: 10px;*/
    see if that helps and check the other pages…….
    Hope that helps
    Thanks swissa 🙂
    @robnob: Did you try with above solution? Let me know if you need further help.
    robnob Friend
    #454722
    Unfortunately i cannot change Ja-Mass-Top or JA-Inner because the padding is used on every page of the site and is how i want it.
    The only page that has that extra padding is on the home page.
    There has to be a reason why?? hmm..
    <em>@Saguaros 321573 wrote:</em><blockquote>Thanks swissa 🙂
    @robnob: Did you try with above solution? Let me know if you need further help.</blockquote>
    swissa Friend
    #454739
    <em>@robnob 321891 wrote:</em><blockquote>Unfortunately i cannot change Ja-Mass-Top or JA-Inner because the padding is used on every page of the site and is how i want it.
    There has to be a reason why?? hmm..</blockquote>
    Then I think you only have one more possibility and then only with 10px.
    templates/ja_methys/css/mod_jacontentslider2.css line 34
    .ja-contentslider-center {
    margin: 5px 5px 5px 10px; <change the 10px to 0px
    padding: 0;
    float: center;
    position: relative;
    overflow: hidden;
    border-bottom: 1px solid
    #E5E5E5
    Best of luck!
    robnob Friend
    #454756
    Thanks Swissa! You’re the best!
    I actually just was fiddling with it and came across the same thing.
    I changed the contentslider line instead of the contentslider-center line.
This topic contains 7 replies, has 3 voices, and was last updated by  robnob 12 years, 7 months ago.
