Radonja Djurisic Friend
Radonja Djurisic
- 72 times in 15 posts
January 6, 2018 at 11:07 pm #1085237Hello,
When i change the module name from "hot products" to "hot proizvodi" and css mess up on that module on homepage
Saguaros ModeratorSaguaros
January 8, 2018 at 4:52 am #1085470Hi,
I think it’s not from the title, if you inspect element of both module, you will see that the product in HOT PROIZVODI module has bigger size in height (268px), while the next module is only: 228px so it doesn’t look nice. Try to use the same size for images of product.
Radonja Djurisic FriendRadonja Djurisic
January 8, 2018 at 10:27 pm #1085640Hi Saguaros
it has nothing to do with image size! if u try to edit module from front end it will mess up
see images
solution is… go to phpmyadmin table > modules > find the module and edit "params" from "no-padding":"0" to "no-padding":"1"
if u have any simple solution plz let me no
by the way is it safe to update to Joomla 3.8.3 ?
Thanks Tolja
- This reply was modified 6 years, 11 months ago by Radonja Djurisic.
Viewing 4 posts - 1 through 4 (of 4 total)This topic contains 3 replies, has 2 voices, and was last updated by Saguaros 6 years, 11 months ago.
