scotty Friend
scotty
- March 2008
- 827 times in 595 posts
cjmicro Friendcjmicro
- June 2008
- 81 times in 10 posts
December 11, 2008 at 3:26 pm #282364Scotty, thanks, that’s what it looked like to me. Do you think making the content inside narrower would help? with contentpane table as I mentioned above.
scotty Friendscotty
- March 2008
December 11, 2008 at 4:03 pm #282367contentpane will only go bigger than it’s container (ja-content) if what’s inside stretches it bigger. The problem is not contentpane. The problem is the content that’s inside it (ie. the html that makes up the article.)
What page do you still see a problem on? It looks fine on my IE7
EDIT: nevermind, see it now.
scotty Friendscotty
- March 2008
December 11, 2008 at 4:26 pm #282374The problem is still the image I think. The max size is 475px, which is what the images were. But they had, and still have, a hspace of 12px applied. This effectively makes them 12px bigger. So the new images are 468+12 = 480px. 5px bigger than the max. This will cause 5px of text to be cut off in IE.
The solution is to remove the hspace or make the images smaller again. I’ve just noticed this site is Joomla 1.0 but that shouldn’t make a difference.
1 user says Thank You to scotty for this useful post
- June 2008
December 11, 2008 at 4:39 pm #282376Yes, to see how this works, I would delete the images from the content and you should see that it all fits fine. Thanks Scotty!
I copied the source and tried this and it does seem to be the images.
Cheryl
December 12, 2008 at 9:14 am #282555Hi and thanks for all your response!
I try to eliminate the big image (chateau_accueil.jpg) in the first page (“Château”) and the text is ok! But…..
When i put my image at 463px (5px less..) the text il always cut !!! 🙁
Cjmicro, i’ve the web developper css for ff and y try to change but no succes..i try too to put width 100% but the slideshow go to the left and it’s not beautiful..
I don’t change anything in the original css (i can to send if you like..) How is it possible?
I know a little css but i don’t resolve this problem.. In the original ja pyrite template the image have 475px and all is ok..? or not..?December 12, 2008 at 10:39 am #282576YESSS, I’m very happy, i find the solution!
You go to the template_css.css and you put in the line number 397 (table.contentpaneopen td, table.contentpane td) width : 463px and all runnig well good !!!
Thanks for all messages for try to help me, i appreciate.
See you later,
brieuccjmicro Friendcjmicro
- June 2008
December 12, 2008 at 10:58 am #282581Yes but now you have fixed width on one area and fluid on others… but since the template is based on a fixed width who knows… as long as it works for you! Glad you found it.
CherylDecember 12, 2008 at 11:38 am #282588Ok i resolve this problem and now i’ve my little icon (pdf, print and send mail) who ‘re separate.. i go to see where’s the problem for that ..
This topic contains 25 replies, has 4 voices, and was last updated by cjmicro 15 years, 9 months ago.
