  • adrew Friend
    #120857
    I’m a Joomla noob and am going through the process of learning the system, so please bear with me.
    I have installed a bunch of free (but ugly) Joomla themes and they all work fine with my cheapo GoDaddy hosting plan. I purchased a membership here for the JA Teline theme, but it does not display correctly — in fact, none of the recent themes display correctly. I downloaded an older one (JA Antares) and it works fine, but none of the newer ones work.
    Is the version of Joomla that GoDaddy has installed (1.0.12) incompatible with the newer themes?
    After I FTP the templates to the templates directory on the web server, they show up in the Templates Manager, but I don’t get a thumbnail “snap” image when I hover over the name.
    Any ideas?
    Here is a screenshot of what I get when I select JA Teline:
    http://spubs.info/teline.png
    Thanks,
    Adam
    Menalto Friend
    #222225
    Try to reupload the template by ftp or use the installation manager in joomla, it seems like that all files isnt uploaded correctly.
    adrew Friend
    #222228
    Ah, thanks. I used the installation manager rather than FTP’ing it over and it worked. Thanks again.
    bigrk Friend
    #222233
    You should mark this thread as solved. 😉
This topic contains 4 replies, has 3 voices, and was last updated by  bigrk 17 years, 6 months ago.
