Viewing 15 posts - 1 through 15 (of 20 total)
  • msilac Friend
    #186409
    Regards,
    I have some problem with displaying articles. Look at the frontpage. The text is too wide and some module appears above articles … I just turned on the option to profiles home – home and show he main content. Everything else is default…
    http://www.mojaakcija.com/TESTING/cepin
    Hi msilac,
    If you don’t want to show those modules in homepage you can check the page assignment section in backend settings of those modules.
    With the text, you can use editor like Firebug in Firefox to make your own change.
    msilac Friend
    #488792
    Ok, I know for a module, but what happens to the title text of articles on the front page when I choose HOME as the default profile template? Like it was too wide for the space on the frontpage
    Edit: I do not see anywhere Custom html module published !?
    msilac Friend
    #489129
    Please, help…
    Dear msilac,
    It seems that these are featured articles in main content block of your site. You can use Firebug to change, if it’s difficult for you, tell me how you want to achieve, I shall check for you.
    msilac Friend
    #489290
    Indeed, I do not use firebug, I looking now at the firebugbut I do not understand anything. I just want the article title text to look normal on the frontpage inside the main content area.
    Could you update the admin account again? I tried to access backend with info you sent me but it seems to be incorrect one.
    msilac Friend
    #489412
    You have PM
    Dear msilac,
    It’s the same with the old info you sent me and I still could not access, kindly check again.
    msilac Friend
    #489504
    Can you check now?
    Henry Kingman Friend
    #489542
    I have the same problem… the “blog” div is cutting off the edge of the text on blog layouts.
    Looking at the “Pages” blog page on the JoomlaArt template demo site, I see it is wrapped in a <div class=”blog clearfix”>
    Meanwhile, the blog layouts I create have only <div class=”blog”>
    How to fix?
    Thaks
    msilac Friend
    #489555
    We need help! 🙁
    msilac Friend
    #489634
    It is urgent now….
    #489637
    I got a decent looking blog layout by having only leading articles (no intro articles) and adding clearfix to the classes. Hope it helps
    msilac Friend
    #489640
    Yes, Main menu – homepage – choose leading articles do the job. (I wonder how Saguaros did not know that?)
    Only one thing… dont know where is that module above articles… so I can disable that module.
This topic contains 20 replies, has 3 voices, and was last updated by  Saguaros 11 years, 7 months ago.
