Viewing 5 posts - 16 through 20 (of 20 total)
  • Saguaros Moderator
    #490128
    Because I cannot log into the backend of your site so that I didn’t know how you configured the home menu item. Please update the url of your site again. I will check for you.
    Henry Kingman Friend
    #492392
    Can you tell me whether the demo for this template is j2.5 or j3.0?
    I decided to try this template again, for another site… so install the J3.0 quickstart… and hitting the same problem: left side of blog items cut off. Oy.
    Thanks ahead of time for any help with this. Would really like to figure it out!
    Hi guys,
    This template can run with both Joomla 2.5 and 3.0. You can pm me admin & ftp account of your site and send me url of page where problem can be seen, I will check for you 🙂
    #492490
    I have confirmed that this template is fine in joomla 2.5. So, it’s only 3.x that has the problem. As this is one of your more popular templates, a lot of people are going to hit this bug now that 3 is “recommended for most new Joomla sites.” Might be worth your time to fix. Just sayin’
    Hi hkingman,
    The demo site is using Joomla 2.5. I also try to create a new menu item with type of “Category Blog” but I cannot reproduce error like you described.
    Please tell me details of how you configured, it will help much.
    Thank you.
This topic contains 20 replies, has 3 voices, and was last updated by  Saguaros 11 years, 7 months ago.
