  • msilac Friend
    #173372
    I have problem with .css. There is one background that I need to have behind template. Background is 1500×1650 pix. In the middle is just white space.
    But when you look in bigger resolution, it is mess… please advice about .css variables…
    I have edit only template.css
    Thank you
    swissa Friend
    #436312
    Can you post the url and turn off optimise css in your template. Thanks.
    msilac Friend
    #436314
    swissa Friend
    #436319
    You need to edit this file ja_bistro/css/template.css
    You have two areas where it is trying to place the background image.
    so at about line 26
    It currently looks like this
    body#bd { background: url(../images/pozadina.jpg) repeat #EFD7B4; color: #666; }
    You can change it to
    body#bd {
    background: url(../images/pozadina.jpg);
    background-size: 100%;
    background-repeat: no-repeat;
    At about line 472 you can see this
    #ja-wrapper {
    background: url(../images/pozadina.jpg) no-repeat left -220px;
    overflow: hidden;
    You need to delete the image here. It is what was causing the problem.
    msilac Friend
    #436324
    Ok, done like you say.
    For second I have delete like this
    #ja-wrapper {
    background: url() no-repeat left -220px;
    overflow: hidden;
    Look now. I think that it is ok.
    swissa Friend
    #436329
    Much better!
    If you want to you can delete all of this
    Well done! 🙂
This topic contains 6 replies, has 2 voices, and was last updated by  swissa 12 years, 10 months ago.
