  • librandi Friend
    #1005696
    I have a big problem with css:
    I upload a new component but some buttons are invisible (cattura, cattura1).
    I write joomevents developer, please read the xjoomlart and please help me
    thankyou very much
    1. xjoomlart
    2. Cattura-2
    3. Cattura1-1
    Pankaj Sharma Moderator
    #1005723
    I Turned ON the Legacy Compatibility option from template options and now you can see the buttons are showing: http://prntscr.com/e0i3vr
    Actually the template is based on Bootstrap3 and the 3rd party extension seems using Bootstrap2, so the Legacy option must be on to BS2 style.
    I guess this 3rd party extension uses Bootstrap 2 while Uber is implemented with Bootstrap 3 so there is conflict in style there. First of all, you can try accessing the Administrator Panel > Extensions > Templates > select your default template style > General tab > enable Legacy Compatible option.
    If there is no go, you can clarify step by step / which URL should I access to see the issue, I will check for you.
This topic contains 2 replies, has 3 voices, and was last updated by  Saguaros 7 years, 9 months ago.
