test melih
 melih
  • doorknob Friend
    #192965
    When an inactive item in the main menu is hovered, the styling changes to the configured ‘hover’ state style exactly as expected. However, almost immediately, a js process adds the class ‘open’ to the parent li element. This has the effect of changing the styling again to the style for the active item. This flickering effect is not noticeable with the colours set to the default values but if the text colours @navbar-default-link-hover-color and @navbar-default-link-active-color) and/or the background colours @navbar-default-link-hover-bg and @navbar-default-link-active-bg) are made very different from each other, the flicker is very noticeable.
    Phil
    Using T3 Bs3 Blank v2.0.0
    T3 plugin v2.0.1
    Chrome browser v31
    Hi Phil,
    Could you turn off Optimize CSS option in template manager and post your site URL here for further checking? some screenshots of what you want to achieve would be better.
    doorknob Friend
    #515612
    I can’t find an Optimize CSS option but I am running with Development Mode on. I can’t give access to the site because I do all of my initial evaluation and development work in localhost. You can demonstrate the effect in development mode by adding the following to the end of the less/variables.less file:
    @navbar-default-link-hover-bg: @red;
    @navbar-default-link-active-bg: @green;
    It’s quite hard to give you exact solution without seeing what you’re trying to achieve. It’s best if you bring your site online or build a demo site via our Demo Builder tool so that I can check and help you.
    doorknob Friend
    #515738
    Thanks for the offer but I’ll be able to sort things out. I just thought I’d let you know about it because it seems like a problem with the famework.
    Phil
    doorknob Friend
    #515898
    This seems to sort it out:
    .navbar-default {
    .navbar-nav {
    > li > a {
    // Inactive main menu item
    color: @navbar-default-color;
    &:hover,
    &:focus {
    // Transition needed from all states because hover triggers the addition of the class 'open'
    .ja_transition();
    > .active > a {
    // The currently selected main menu item
    &:hover,
    &:focus {
    color: @navbar-default-link-active-color;
    background-color: @navbar-default-link-active-bg;
    .ja_transition();
    > .active.dropdown > a .caret {
    &:hover .open,
    &:focus .open{
    border-top-color: @navbar-default-link-active-color;
    border-bottom-color: @navbar-default-link-active-color;
    .ja_transition();
    &:hover .open,
    &:focus .open{
    border-top-color: @navbar-default-color;
    border-bottom-color: @navbar-default-color;
    .ja_transition();
    > .open > a {
    // Hovered menu item (including while dropdowns remain active)
    &:hover,
    &:focus {
    // The currently hovered main menu item
    color: @navbar-default-link-hover-color;
    background-color: @navbar-default-link-hover-bg;
    .caret {
    border-top-color: @navbar-default-link-hover-color;
    border-bottom-color: @navbar-default-link-hover-color;
    // Note: Gradient to gradient transitions are not implemented in CSS3'
    .ja_transition @Duration: 0.5s, @ease: ease) {
    -webkit-transition: all @Duration @ease;
    -moz-transition: all @Duration @ease;
    -o-transition: all @Duration @ease;
    I left the transitions in but they can be taken out again of course.
    Phil
    edited to add corrected colouring of the caret
This topic contains 6 replies, has 2 voices, and was last updated by  doorknob 11 years, 1 month ago.
