  • stanman123 Friend
    #149222
    Every page that is a link to a component has problems with the display above the link title.
    To see examples of what I’m talking about check out a normal page that just links to a regular article/content item:
    http://sandbox.theweboasis.com/lebois/how-can-le-bois-realty-help-you-reduce-the-stress-of-buying-or-selling-real-estate.html
    See how the rounded corner outline looks normal and good immediately above the text that says “How can Le Bois Realty help you reduce the stress of buying or selling Real Estate?”?
    Now look at this page:
    http://sandbox.theweboasis.com/lebois/listings/
    See how the rounded corner outline has extra, unwanted stuff immediately above the text that says “Le Bois Realty”?
    Why is this happening and how do I fix it?
    Dear stanman123!
    i have not a clear understanding on the issue, if possible give me the snapshort and draw some rectangles above some problem posiblems on this snapshort.
    And i saw the top rouded box has a problem, pls fix this as following:
    Add these codes into the template.css file:
    .componentheading h1 {
    margin:0px;
    font-size:120%;
    font-weight:bold;
    padding-top:10px;
    stanman123 Friend
    #335238
    That fixed it; thanks!
This topic contains 3 replies, has 2 voices, and was last updated by  stanman123 14 years, 8 months ago.
