  • Andrew Winkler Friend
    #205280
    I have the problem that the hero text of the module ” Intro Images” is too big to fit on the ipad screen. I tried to write an overwrite in custom.css, but that did not work. The custom.css is being ignored. I then upgrade the template to the last version and now I have even more problems.
    1. The overwrite in the custom.css is still being ignored.
    2. I now have a huge gap in between the top menu and the module ” Intro Images”.
    3. I tried getting rid of that gap too by reducing the top margin of 104px to 0px in a custom.css overwrite, but that gets ignored too.
    4. The tab in the backend module configuration where I could edit the hero text for the module ” Intro Images” is no longer displayed.
    Adam M Moderator
    #565920
    Hi @andrewwinkler,
    I temporary disable CSS / JS Compression in Template Manager >>> your template >>> tab General and the problem with custom.css file has been solved.
    About the gap between Main Menu and first section block, please open custom.css file and add this code :
    .sections-wrap .section:first-child .section-inner {
    padding-top: 0;
    Another matter is the module description text, you can add it in tab JA Extra Fields >>> Module Intro Text when in module setting panel.
This topic contains 2 replies, has 2 voices, and was last updated by  Adam M 9 years, 8 months ago.
